Rear Differential, Is the friction reducer required for my truck?
252,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MORGANIZER032
Is the friction reducer required for my truck? (Limited slip)
May 22, 2023 at 12:11 AM
BRENDON S
  • 653 POSTS
Hello MORGANIZER032,
Yes. All Ford limited-slip rear axles require 4oz or 8oz of Friction Modifier Motocraft XL-3 whenever servicing equivalent depending on axle size. I have added an image of the fluid specifications chart depending on axle size as well as a photo of the Motocraft product for you. I would just go to Ford for it personally.
Thank you,
Brendon
May 22, 2023 at 3:43 AM
