The differential fluid appears to be coming out of the vent hose?
250,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
CRAZYDOG72
  • 13 POSTS
I didn’t feel any fluid when I stuck my little finger in there. What could be the cause of this and how do I fix it? I recently got the vehicle listed above and I don’t know much about it.
Jun 21, 2024 at 11:02 PM
  • 55,688 POSTS
Yep, this can happen when the differential overheats due to gear oil that needs to be replaced or there is a mechanical failure causing the problem, either way I would remove the rear diff cover to inspect the gears and fluid conditioner, (check the fluid for metal flakes). Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/differential-service
Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with.
Jun 23, 2024 at 4:29 AM
CRAZYDOG72
  • 13 POSTS
Okay, there is also a hum or something is vibrating when I let off the accelerator above 60+. Could it be the gears or the driveshaft?
Jun 23, 2024 at 4:56 AM
  • 55,688 POSTS
Yep, is the hum coming from the rear of the car? If so, it could be the rear end is having an issue. I would remove the rear cover to see what's going on. Also, you can remove the driveshaft to check the U joints.
Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
This guide can help as well:
https://www.2carpros.com/articles/how-u-joints-work
Jun 24, 2024 at 1:51 AM
CRAZYDOG72
  • 13 POSTS
Yes it is.
Jun 24, 2024 at 9:47 AM
  • 55,688 POSTS
Yep, this can be an issue, please upload images or a shot video of the problem once you have done the work.
Jun 25, 2024 at 3:07 AM
