Rear Deferential
123,000 MILES • V8 • AUTOMATIC
JANAE DIOR
Okay, the dealer says it is leaking, will that also make my transmission temperature go over two hundred degrees?
Jul 18, 2016 at 5:02 AM
HMAC300
  • 48,601 POSTS
it should not, but if transmission light is not on then do not worry about the temperature. you can always add a transmission cooler to it anyhow to run it a little cooler.
Jul 18, 2016 at 5:23 AM
