Rear deck latch will not latch
1,444,444 MILES • 3.8L • V6 • FWD
CMZANNN
  • 84 POSTS
The only place to come when you need a problem solved correctly is here. money or no money, which puts you far and away the beat. I just got the car listed above it is a drop top, cherry. I opened the rear deck using the button on the dash,nothing. so I then pushed the picture on the key chain that came with car it opened. when finished I closed the trunk thinking it latched got in car fired her up down the road. I went I hear a ding like set belt not on it s on. I hear it again looking at dash below speedometer rear deck spelled out. I pull over go to close it tight jump in light still there. I try again little harder and it will not secure. I have messed around with it it does not appear that anything broke the white plastic piece that moves when pushed on key chain moves, but trunk will not latch. is there a way to fix?
Mar 15, 2017 at 6:35 AM
CARADIODOC
  • 34,414 POSTS
There are a couple of things to consider. First, if this is a standard latch mechanism, there could be a spring missing in it. That spring rotates the hook that does the latching to the bar on the underside of the trunk lid. That hook could also be rusty. A squirt of Mopar Spray White Lube works well for that. It goes on rather watery and soaks into the tight places. The juice takes the grease with it, then the juice evaporates and leaves the grease behind.
You may also have an electric soft pull-down latch. When you pop the latch, you'll hear the motor run for a couple of seconds as it raises up the latch. To close the lid, you only lower it gently until the latch catches it and pulls it the rest of the way closed. If the fuse is blown, the latch will not extend, then that can make it hard to slam the lid enough for it to latch. You have to slam it hard enough to compress the weather strip.
You can use the shank of a screwdriver to mimic the bar on the bottom of the trunk lid. Use it to push the latch down just like the bar would. You might see another lever rotate and snap into place to lock the latch, and you will hear it snap if it is rotating freely. At that point you have to unlock it before it will work again.
If you have a standard latch, someone may have adjusted it down too far, so now the lid has to be slammed really hard to get it to latch. A potential clue is the weatherstrip around the trunk opening is chewed up from being over-compressed, or, if it is only damaged in one area, someone may have damaged it, then over-adjusted the latch to compensate and stop water from getting in.
You can get better advice, usually for free, from the people at most body shops. They are specialists at adjusting latches, and addressing wind and water leaks. To be safe, visit a shop during their lunch hour. Most employees are paid by the hours they have on a job, and prefer to not be distracted during those working hours.
Mar 15, 2017 at 9:16 AM
