Rear clunky noise
180,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MIKE1961
  • 25 POSTS
My daughter's car has a slight clunk noise at the rear of the car when going over small bumps in the road. My guess is a loose or worn out linkage. Any ideas?
Nov 26, 2017 at 3:31 PM
CARADIODOC
  • 34,415 POSTS
The best approach is to have the steering and suspension systems inspected at a tire and alignment shop. The people there are experts at finding the causes of noise, vibrations, and bad tire wear.
The best suspects are a worn anti-sway bar link or a sloppy strut, but we also see a lot of deteriorated control arm bushings. At the mileage you listed, a broken rubber exhaust hanger is another good suspect. That can let the tail pipe bang on something.
Nov 27, 2017 at 11:46 AM
