Rear clunk noise
170,000 MILES • 7.3L • V8 • 4WD • AUTOMATIC
CHRISITNE
When I apply my brakes I hear a loud clunk noise (only once when applying brakes), it sounds like it is coming from my driver side rear tire area. when I release the brake it is a lighter clunk sound. It does not do this in reverse when braking. Also, when going over washboard road it sounds like something is loose, same area. Any thoughts would be great.
Thanks,
Christine
Nov 14, 2017 at 8:20 AM
  • 110,251 POSTS
Christine:
Safely lift and secure the vehicle. Remove the wheel where the noise seems to be coming from. Remove the brake drum or rotor to see of there are any broken springs or lose components. That is where I would start. Let me know what you find.
Nov 14, 2017 at 11:48 AM
CHRISITNE
I did remove the tire this afternoon, but with limited time I just looked for anything out of the norm. I will check it out tomorrow, I appreciate your input!
Nov 14, 2017 at 12:10 PM
  • 110,251 POSTS
Not a problem. Let me know what you find.
Nov 15, 2017 at 12:14 PM
CHRISITNE
A bolt missing on my caliper....... easy fix, yay! Thank you
Nov 15, 2017 at 10:05 PM
  • 110,251 POSTS
That will do it. lol. Not a safe problem, though. Glad you got it fixed!
Nov 16, 2017 at 8:58 AM
