Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Town and Country
Brakes
Pads
Rear
Rear brake caliper piston will not re-track.
2011 CHRYSLER TOWN AND COUNTRY
52,000 MILES • 4.6L • 6 CYL • 2WD • AUTOMATIC
DARLINE RANSON GURNEY
MEMBER
1 POST
rear brake caliper piston will not re-track.
Jun 8, 2017 at 8:11 AM
Experienced Mechanic
Here is a video that will help with this:
https://youtu.be/hPzxdnLJbhc
and
https://youtu.be/j8YwfSKEzZo
If it will not retract then you are going to have to replace it as it is seized or the fluid is not being allowed to return.
Here is a guide that will help replace the brakes and caliper as you will most likely need to replace both while you are there:
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
and
https://www.2carpros.com/articles/brake-caliper-replacement
Below is the process for this as well from the manual. Let us know if you have other questions. Thanks
Images (Click to enlarge)
Mar 12, 2021 at 9:39 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
