Rear brakes grinding sound
2004 SUBARU OUTBACK
189,000 MILES • 2.5L • 4 CYL • AWD • AUTOMATIC
ELIJAHCHESTER
Hey, I started hearing a grinding sound in rear drivers side brake area about a week ago, both when applying brakes and even a bit when not applying them. So I inspected the rotors and pads and pads. definitely needed replacing. also, there will indentations on rotors. Do not think rotors had ever been replaced.
I removed both rear rotors and pads today and replaced (which was not fun for a while because of the caliper brackets bolts being stuck). Anyway, put it all back together and did small test run and I am still hearing grinding noise when I am coasting. Not so much at all when applying brakes. Could something like the bushings, or slide bolts in the caliper be in need of replacing too? Or is there something that is causing this grinding sound?
thanks.
Elijah
Jan 27, 2017 at 1:53 PM
HMAC300
  • 48,601 POSTS
if you did not check the parking brake that ruins the inside of the rotor or clean the junk from caliper like rust and mud that can be giving you the noise.
Jan 27, 2017 at 11:03 PM
ELIJAHCHESTER
I cleaned the caliper bracket and caliper a little bit and got off all the excess dirt. Could it be something like the wheel hub assembly? Is that what it is called? The bearings?
Jan 27, 2017 at 11:20 PM
yes, the hub bearing assembly is a common issue for grinding. sometimes you can spin the wheel by hand and feel the roughness . make sure there is no side to side play in the wheel indicating a bearing being loose
Jan 30, 2017 at 10:28 PM
