Is a special tool needed to compress the plunger on the rear caliper when replacing brakes on my GT?
Jul 6, 2016 at 2:18 AM
HMAC300
✓Experienced Mechanic
it may be the parking brake is holding it up. if you see two or three small holes or a square you may need a tool to turn piston back into the caliper. the one in picture is a Ford tool however auto parts have these just a bit different.this will show ho to retract the caliper
