rear brake third light
200,000 MILES
KEITH MCCAFFERTY
The rear brake third light is not working.
Jun 12, 2017 at 4:55 AM
HMAC300
  • 48,601 POSTS
check bulbs we have no instructions on how to replace those look for screws on outside then check the light green wire going to it for power may be the problem.
Jun 12, 2017 at 5:15 AM
KEITH MCCAFFERTY
It appears to be a sealed unit connected to exterior trim.....do you have to replace whole unit?
Jun 13, 2017 at 6:58 AM
HMAC300
  • 48,601 POSTS
no you shold be able to acces it from behind inside cab. check for a removable panel to access it would be bolted from behind and give bulb access as well.
Jun 13, 2017 at 8:12 AM
