Rear brake noise goes off when brakes applied
26,000 MILES • 2.0L • 4 CYL • TURBO • FWD • AUTOMATIC
PARTH PATEL
My rear brake starts to give out some noise after few minutes when i start driving the car and then when i apply the brakes the noise goes off, and comes in again when i release the brakes. The noise tends to be louder at lower speed and goes off at higher speed (only some times).
Really annoyed with the noise, plus i replaced the brake pads and also got my rotors re-surfaced. And the the noise started to come after say one month of replacement of the pads. and only one side (rear left side) give this annoying noise.
Really need help.
Aug 14, 2016 at 7:45 AM
  • 31,937 POSTS
Check the brakes for correct fitment and that all bolts are tight, ensure backing plate is not bent and touching rotor, also check that there is not a stick or stone lodged in the brakes touching the rotor, this is a very common cause of odd noises in brakes.
Aug 15, 2016 at 11:19 PM
