Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Vibe
Brakes
Caliper
Replace/Remove
rear brake caliper
2009 PONTIAC VIBE
174,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DENNIS PILCHER
MEMBER
1 POST
Have the tools and I want to replace the brake caliper
Feb 26, 2018 at 10:05 PM
SQM
Experienced Mechanic
I have attached the complete rear brake replacement procedure including the pads, rotors, and calipers.
You will have to use the special tool to retract the piston back into the housing.
Here is a helpful video:
https://youtu.be/j8YwfSKEzZo
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Images (Click to enlarge)
Oct 8, 2021 at 6:00 PM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
