Rear body bushings replacement
2002 TOYOTA CAMRY
181,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JEFF HERMAN
  • 486 POSTS
I was wondering if you knew of a video showing replacement of the rear body bushings on this vehicle. The bolt loosens from underneath but won't come out. Are these bushings pressed onto the rear sub frame? The replacements don't appear to be press fit. How do you access the top bushing cap that I assume is the threaded one to hold it while the bolt is removed? Any assistance would be greatly appreciated as always. Thank you .
Nov 6, 2019 at 11:41 AM
MASTERWRENCH
  • 258 POSTS
On most uni-body type vehicles, these sub-frame bolts thread into a "captive nut" that's actually welded in place inside the body/frame rail. If the bolt is turning but not coming loose, that generally means the captured nut has broken loose and is spinning inside the frame rail. There's no official way to fix something like this. Most technicians look for an appropriate area on the body/sub-frame rail to cut an access hole to repair the nut. I can't say exactly where this should be done as it differs from vehicle to vehicle. It also requires cutting and welding a structural part of the vehicle, so it's something that should be performed by an experienced body technician.
Nov 6, 2019 at 2:14 PM
JEFF HERMAN
  • 486 POSTS
That's kind of what I thought.
Nov 6, 2019 at 7:05 PM
