Good call sir!
So, I saw your reply at 0530 here and just couldn't wait to try it. Ran a jumper write to a good, known ground and the fan came on, but with some interesting quirks. While hooked directly to ground the fan was on high, regardless of the setting at the rear controls. If I jiggled the wire that I had shoved in the back of the fan connector it would vary the fan speed. I pulled the ground wire before I s*** off the vehicle and the fan started somewhat working as it should, just weak. Like I was able to change the fan speed at the rear controls and could hear it change but overall it was much weaker than it was supposed to be. That lasted about 3-5 seconds before it shut off completely. Those dots were me having an epiphany in the middle of typing and running back to check something. I just shoved my jumper ground wire back into the orange wire in the plug at the fan and it works as it should. There is some sort of bad connection on the ground side at the plug.
Thank you sir, without your guidance I would have never figured that out. You are a rock star!
One takeaway that I have gotten is that the fan speed seems to be controlled by the ground and not the power. Makes sense now that everything is laid out but didn't before. Hopefully this further troubleshooting will help someone else in the future.
Mar 29, 2021 at 9:17 PM
