Rear blinkers on right side not functioning properly
112,200 MILES
DANLABAY
Could I have a flasher problem if one blinker build on the rear passenger side is working and the other two are not ? Also blinkers on left side are all working in the rear of my car listed above GT Premium ? Do you think if I replace the flasher it will fix the problem ?
Jun 21, 2019 at 5:02 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds to me like you have a burnt out tail light. I have included a couple of links below for you to go to.
https://www.2carpros.com/articles/turn-signal-bulb-replacement
https://www.2carpros.com/articles/reverse-light-bulb-replacement
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jun 21, 2019 at 5:21 PM
