rear bearing hub removel
109,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
PAPERM7600
I have removed the 4 bolts and shaft nut from the hub assembly the hub will not come off the shaft with a 5 ton puller why?
Dec 27, 2015 at 3:50 AM
there is corrosion between the hub and the spindle. a dead blow hammer is needed to help break it loose. if you have an air hammer, it will also help to remove it.
Dec 27, 2015 at 4:32 AM
JDL
  • 16,098 POSTS
Sometimes, I use rust lube spray and then put a good bind on the puller and walk away and leave it for a while, go do something else. Then come back and try to put some more torque on the puller, walk away and leave it again. If your not going to use the hub again, you might try pecking around on it with a four pound hammer.
I'm not sure about using heat or a cutting torch on it? Maybe some of the others can jump in, I doubt if they will, though?
Dec 27, 2015 at 4:47 AM
JDL
  • 16,098 POSTS
Hi Roy, didn't see you, have a good day.
Dec 27, 2015 at 4:48 AM
PAPERM7600
thank you for the info I thought I was doing something wrong
Dec 27, 2015 at 4:57 AM
