Rear axle bearing and seal removal
100,000 MILES • V8 • 4WD
RUTHIJEAN
Rear Axle has axle lockers in the rear end. I cannot find anywhere on the internet that shows how to remove these locks. I need to replace the seal and bearing Can you help?
Jun 23, 2016 at 6:10 AM
  • 110,248 POSTS
The job can be tricky but we have made a great video on how to do the job plus instructions in the diagrams below to show you how step by step.
Video: https://youtu.be/zarxKsspr3s
Guide: https://www.2carpros.com/articles/rear-axle-seal-replacement
Rear Axle Shaft Seal and/or Bearing Replacement
Special Tools
* J 2619-01 - Slide Hammer W 1/2 x 13 Adapter
* J 8092 - Universal Driver Handle 3/4 x 10 inch
* J 21128 - Axle Pinion Oil Seal Installer
* J 23690 - Axle Bearing Installer
* J 44685 - Rear Axle Seal and Bearing Remover
* J 45857 - VSES Wheel Bearing Remover
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle (See: Vehicle Lifting > Procedures > Lifting and Jacking the Vehicle).
2. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation (See: Wheels and Tires > Removal and Replacement > Tire and Wheel Removal and Installation).
3. Remove the rear axle housing cover. Refer to Rear Axle Housing Cover and Gasket Replacement (8.6, 9.5 Inch Axles) ()Rear Axle Housing Cover and Gasket Replacement (10.5/11.5 Inch Axle) ().
4. Remove the axle shaft. Refer to Rear Axle Shaft Replacement (See: Axle Shaft > Removal and Replacement).
Note: If the vehicle is equipped with VSES, proceed to step 5.
5. Using the J 44685 - remover (1) and the J 2619-01 - hammer (2), remove the rear axle shaft seal.
6. Using the J 45857 - remover (1) and the J 2619-01 - hammer (2), remove the rear axle shaft seal, bearing and the wheel speed sensor reluctor ring, if equipped.
Installation Procedure
1. Install the rear wheel speed sensor reluctor ring, if equipped.
* For vehicles with the HP2 (Hybrid) option, refer to Rear Wheel Speed Sensor Ring Replacement ().
* For vehicles that are NON-Hybrid less than 3900 kg (8600 lbs) GVW, refer to Rear Wheel Speed Sensor Ring Replacement (See: Wheel Speed Sensor > Removal and Replacement > Non-Hybrid Less than 3900 kg (8600 lb) GVW).
* For vehicles that are NON-Hybrid greater than/equal to 3900 kg (8600 lbs) GVW, refer to Rear Wheel Speed Sensor Ring Replacement (See: Wheel Speed Sensor > Removal and Replacement > Non-Hybrid Greater than/Equal to 3900 kg (8600 lb) GVW).
Note: Ensure that the axle shaft bearing is fully seated in the rear axle shaft housing.
2. Using the J 23690 - installer (1) and the J 8092 - driver (2), install the axle shaft bearing.
3. Using the J 21128 - installer , install the axle shaft seal.
4. Drive the tool into the bore until the axle shaft seal bottoms flush with the tube.
5. Install the rear axle shaft. Refer to Rear Axle Shaft Replacement (See: Axle Shaft > Removal and Replacement).
6. Install the rear axle housing cover. Refer to Rear Axle Housing Cover and Gasket Replacement (8.6, 9.5 Inch Axles) ()Rear Axle Housing Cover and Gasket Replacement (10.5/11.5 Inch Axle) ().
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation (See: Wheels and Tires > Removal and Replacement > Tire and Wheel Removal and Installation).
8. Fill the rear axle. Refer to Differential Oil Replacement (10.5 Inch Axle) (See: Fluid - Differential > Removal and Replacement)Differential Oil Replacement (11.5 Inch Axle) (See: Fluid - Differential > Removal and Replacement)Differential Oil Replacement (8.6 Inch Axle) (See: Fluid - Differential > Removal and Replacement)Differential Oil Replacement (9.5LD Inch Axle) (See: Fluid - Differential > Removal and Replacement).
9. Remove the support and lower the vehicle.
Check out the diagrams below: Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jun 23, 2016 at 11:56 AM
GWBROWNJS2014
I am trying to replace a leaking rear axle seal on the passenger side. I have the pin and clip out of the differential but the axle wont slide out. Is there something else holding it in place?
Dec 2, 2019 at 7:52 AM (Merged)
HMAC300
  • 48,601 POSTS
I am assuming this is an 8.6 axle there are 4 different axles so instructions are for a n 8.6 make sure brake drum is off if drum brake and or caliper and caliper bracket as well as rotor. then it should come out. see pic
ALLENSHARRARDSYES ONPROP8
Drive Train Axles Bearings problem
2000 Chevy Silverado V8 Four Wheel Drive Automatic
how do i fix my rear wheel bearings i did my front and have all the equipment but just how do i do it
Dec 2, 2019 at 7:55 AM (Merged)
BLACKOP555
  • 10,386 POSTS
is it one ton? half ton? 3/4?
full floating axles or semi?
[quote:2a13003bea="blackop555"]is it one ton? half ton? 3/4?
full floating axles or semi?[/quote:2a13003bea] 1500 4 wheel drive
BLACKOP555
  • 10,386 POSTS
do you have the tool for pressing out the new bearings and puttithe new ones on the shaft properly?
CARPENTER1954
I raised the rear of the truck up with an air jack and cranked the engine and put it in gear to turn the rear wheels. On the driver side I heard a grinding, clacking sound. I turned the engine off and turned it by hand. The grinding sound was there and the wheel would catch at intervals. I suspected the wheel bearing. The seal was also leaking oil.
I went to all of the trouble of pulling the axle to find that the bearing does not seem to be bad. I see nothing that indicates what was causing the grinding sound. The axle did have a little up and down end play before I took it out but only a little. Puzzeled?
James Hart
  • 110,248 POSTS
Have you checked the bearings in the differential? With the diff cover removed, have a helper turn the wheel to make the noise while you watch and listen at the diff to see if that is where the problem is coming from.
ALLEN2443
2000 chevy silverado 4x4 rear axle seal. How much do you think a job like that would cost ?
BLUELIGHTNIN6
  • 16,542 POSTS
should cost approx. $150 labor and parts, minus tax. that is to remove and replace only 1 side, i would suggest have both replaced at same time.
