Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Drivetrain
Differential
Axle
Bearing
Rear axle nut torque specifications needed?
2019 FORD EXPEDITION
91,000 MILES • V6 • TURBO • 2WD • AUTOMATIC
DCREED
MEMBER
1 POST
I have the bearing assembly and replacement axle hub niy, but can't find the torque specifications for the rear assembly.
Jul 9, 2023 at 3:40 AM
MATHGEN
Experienced Mechanic
The 4 hub bearing bolt torque to 129 lb.ft (175Nm) and the axle shaft nut is 184 lb.ft (250 Nm). Please let me know if you need anything else.
Jul 9, 2023 at 10:39 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
