Differential gear oil type?
112,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
SMALLBLOCK351
I need to know what weight fluid is recommended in the rear-end? Also does it need to be GL-4 or GL-5?
Jul 23, 2016 at 9:18 AM
HMAC300
  • 48,601 POSTS
api -GL5-80w90 gear oil unless a hot climate like Arizona the 90w can be used.
Jul 23, 2016 at 9:44 AM
SMALLBLOCK351
So any brand that is GL5 80w90 or 80w95? I appreciate the information. Thank you.
Jul 23, 2016 at 10:52 AM
  • 31,937 POSTS
Yes, just as long as you use the correct spec oil, but cheap oils are just that. use quality and it will last longer.
Jul 23, 2016 at 11:55 AM
SMALLBLOCK351
Great! I changet my manual transmission fluid with Redline MT90 and it is fantastic! So i am going with Redline for the rear-end also. Thanks again for your help.
Jul 23, 2016 at 12:09 PM
  • 31,937 POSTS
Thanks for using 2CarPros.... tell your friends, we are here for everyone with problems.............
Jul 23, 2016 at 1:28 PM
