With the truck in neutral and the wheel blocked to prevent it from rolling, raise the suspected tire and try to shake it up and down and from side to side and then rotate it listening for noises. If it has movement, it could be a sign of a bad bearing.
Next, remove the tire to get a better view and to check inside of the drum or behind the rotor for signs of axle fluid leaking.
If these problems exist, the axle bearing and seal will have to be replaced (replace both sides).
SPONSORED LINKS
Monday, May 17th, 2021 AT 1:18 PM
