Rear axle bearing?
300,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RWALLACE33
  • 25 POSTS
I have been told by a mechanic my driver side rear wheel bearing needs replaced. Its a Silverado with drums in rear. I've driven on this thing for a couple months changed all the bearings in the front. To find its the rear bearing. When I change this bearing should I expect to have a worn axle shaft too? Should I preemptively purchase one incase. Or is it uncommon for them to be worn. Thanks
Oct 14, 2025 at 10:30 AM
  • 55,616 POSTS
You are correct to get the axle since it is the inner race for the bearing, here is a great video to help you change the bearing out:
https://www.youtube.com/watch?v=zarxKsspr3s
Please upload an image or short videos in your response if you have any issues.
Oct 15, 2025 at 2:33 AM
