Rear A/C clicking
153,000 MILES • 6 CYL • 2WD • AUTOMATIC
NAGB PHILLIPS
We replaced the blend door. We also tested both blend doors and neither made a sound. But there is still a clicking noise coming from somewhere else in the rear unit. What else can it be?
Sep 9, 2019 at 12:50 AM
When you say you replaced the blend doors, I assume you mean the actuators? Also, does it click when the doors are moving or is it a constant click? Can you get a video of the noise before you take anything apart?
If you replaced the actuators, it could still be the plastic gear of the door itself however, I have to say I replaced one of these gears and the new one clicked louder than the failed one. It ran fine when I tested it but when installed it would click due to the stress at the stop points.
What I would recommend is pull it back apart as you are going to replace them again and then run the system and see if you can pinpoint which one is clicking or if it is something else. There are not many moving parts so I am sure you will be able to pinpoint it.
Let me know what you find and we can go from there. Thanks
Sep 9, 2019 at 10:20 AM
