Rear A/C not working properly
2011 DODGE CARAVAN
149,000 MILES
JDOSTER67
Took off panel and vent to the ceiling vents the fan is running strong but no air is coming out.
Please help
Jul 3, 2021 at 3:58 AM
If the rear A/C is the only thing that is not blowing cold it could still be a weak charge in the system so we need to start with this. Here are guides that will get us started:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Once we know what the actual charge is in the system then we can start narrowing it down to just the rear system and a possible door motor issue but if the charge is weak then we will not fix it unless we check this first.
Below is a chart that will help with proper pressures.
Let us know what you find with this and we can go from there. Thanks
Jul 3, 2021 at 11:21 PM
WHISKER
your guides are really helpful! thanks!
Jul 7, 2021 at 4:26 PM
You are welcome. Please let us know if you have other questions and what you find. Thanks.
Jul 8, 2021 at 12:56 PM
JDOSTER67
Thanks again.
Jul 8, 2021 at 12:58 PM
