Really rough idle, misfire and backfire
200,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CRISTY BOLDEN HUMPHERY
Having a really rough gulping like (lol) Idle and revs up on its own while in park. When put in gear it almost shuts off if I don't hit gas, and shuts off sometimes when braking to make a turn.. While driving it has power loss barely wants to go and backfires the whole time. I have put a new Throttle body, MAF sensor, MAP sensor, EGR valve, new plugs and wires. Replaced air filter, checked wires everywhere, nothing has changed. when I put new spark plugs wires on it seemed like it got worse. Fuel pump comes on. Any Ideas would be greatly appreciated.
Jan 10, 2021 at 12:29 PM
We need to check the base engine operation. That means we need to check the vacuum leak and compression to start. Also, we need to check for codes and see what is there.
Here are guides for all that we need to do:
Let's start with this and go from there. However, I suspect we have a larger engine issue so we need to make sure the compression readings are correct.
Let us know if you have questions. Thanks
Jan 11, 2021 at 11:37 AM
