I just had my o2 sensor fix and the codes are cleared, but my evap code and another one or two and it wont pass inspection.
Jul 21, 2016 at 1:34 PM
SATURNTECH9
✓Experienced Mechanic
How far did you drive it after the code was cleared before you had your smog test done?
Jul 21, 2016 at 2:31 PM
AUSTIN HANER
MEMBER
Almost twenty miles and probably five to ten more miles before i take it back in tomorrow morning.
Jul 21, 2016 at 2:48 PM
SATURNTECH9
That is not far enough, sometimes they will set pretty fairly quickly, but a lot of the time it takes a while to set all the monitors because each monitor takes certain driving or engine running conditions so they can set.
Jul 21, 2016 at 2:55 PM
AUSTIN HANER
MEMBER
The person from the garage drove and and he said let it cool down over night and then drive it a little bit in the morning and then bring it in and it should hopefully be able to pass inspection.
Jul 21, 2016 at 4:27 PM
SATURNTECH9
He is very hopeful it can take a while before they set.
