Realignment after dealership replaces lower control arm?
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
CB22
steering wheel position is not at 12:00 after dealership replaced lower control arm. They said alignment was not needed when replacing the lower control arm.
Oct 23, 2023 at 12:21 AM
  • 55,859 POSTS
Generally, this is true, did the car have an accident and this is why the part was replaced? How far off is the steering wheel, can you upload an image of the problem?
Oct 23, 2023 at 2:45 AM
  • 55,859 POSTS
Also, if an alignment was done with a bad part and a new part is installed the car will need another alignment.
Jan 3, 2024 at 8:31 AM
