No power to fuel pump and spark plugs
1997 ISUZU RODEO
155,138 MILES • 3.2L • V6 • 4WD • MANUAL
ISUZU801
Hi, my vehicle was involved in an accident the radiator and grill were smashed and it still would want to start, but after a couple of days after it got to my house no dash and no power to fuel pump and spark plugs check all relays and fuses nothing new computer still no luck. jumped fuel pump relay got pump to work. i need help to figure out what the problem is.
Jul 28, 2016 at 11:02 AM
HMAC300
  • 48,601 POSTS
try resetting your security system if the radiator got smashed then the battery may have gotten it too. if no manual look online for your car. if still not starting have a mechanic scan for codes as it may be a security issue that resetting won't fix.
Jul 29, 2016 at 9:28 AM
ISUZU801
I did replace battery and still no start and can they still scan for codes when no dash lights come on.
Jul 29, 2016 at 11:27 AM
RIVERMIKERAT
  • 6,110 POSTS
Yes. They should be able to. Check the fusible link connection to the distribution box from the battery.
Jul 30, 2016 at 2:37 AM
ISUZU801
Does this have a fuel cut off switch?
Jul 30, 2016 at 10:52 AM
HMAC300
  • 48,601 POSTS
no, just fuse eb11 and eb15 along with a relay.
Jul 31, 2016 at 1:09 AM
