Rattling noise when idle and low speeds?
64,000 MILES • 2.0L • 4WD • AUTOMATIC
JOSHL13
  • 5 POSTS
Got this rattling noise, when idle and low speeds or lowering speed. (Foot off accelerator)
Apr 14, 2026 at 4:54 AM
JOSHL13
  • 5 POSTS
Video of sound
Apr 14, 2026 at 4:55 AM
JOSHL13
  • 5 POSTS
Other video from being idle inside
  • 55,628 POSTS
O man, that is not good, do not drive the car anymore, it sounds like you have a valve train issue like the camshaft actuator, balance shaft or a roller follower, you need to lift the hood and see if you can tell the area of the engine noise, front, middle, under or rear of the engine. That way we can pinpoint the problem, can I ask if the check engine light is on? If so we need to get the codes which can help as well. This video will help.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Has any work to the engine been done recently? thanks for the videos they helped. Ken
Apr 15, 2026 at 12:45 AM
JOSHL13
  • 5 POSTS
Hey! Cheers for the reply mate - No engine codes, got it diagnosed yesterday. No engine light. Drives fine also - No differences in driving
Apr 15, 2026 at 1:00 AM
JOSHL13
  • 5 POSTS
Sound of the noise comes from near the wheel, open bonnet can’t hear it that well. Go down near drivers front wheel hear it clear
Apr 15, 2026 at 1:01 AM
JOSHL13
  • 5 POSTS
Update - Getting P24C7 + “gearbox fault detected. Can’t start car
Apr 15, 2026 at 5:16 PM
  • 55,628 POSTS
The engine is having an issue and if you keep driving it while it is spreading metal throughout the engine it will be ruined. FYI. The P24C7 code has nothing to do with the engine noise. I would remove the valves cover on the drivers side and do an inspection. I would think you will find a broken valve spring or a bad roller follower. Once the valve cower is removed please upload an image or short video so I can see it.
Apr 16, 2026 at 1:56 AM
JOSHL13
  • 5 POSTS
So the sound is coming quite high up, middle of engine (nearer to drivers front wheel - right) - There are some metal shavings on the aux belt.
Apr 16, 2026 at 11:29 PM
  • 55,628 POSTS
Yep, we need to remove the valve cover on the driver side for inspection.
Apr 17, 2026 at 12:44 AM
JOSHL13
  • 5 POSTS
Seems to be the alternator causing the rattle.
Apr 20, 2026 at 5:38 PM
  • 55,628 POSTS
Hmm,, that could be but I would remove the drive belt and start the engine briefly to see if the noise is still there, please let me know. Thanks for the video.
Apr 21, 2026 at 12:15 AM
