Codes p0190 and p0343, rattling after Hpfp and cam follower replacement?
120,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
ADAMJH66
I replaced the Hpfp and cam follower after the old ones failed and now there is a horrible rattling noise coming from the back of the engine. there are also codes p0190 and p0343.
Apr 1, 2023 at 7:13 AM
  • 110,248 POSTS
The P0190 is specific to the fuel pressure sensor. The P0343 is for the camshaft position sensor. I attached pics below for both. Check to see if everything is properly connected.
Next, can you describe the sound? Does it change with engine speed? Is there anything you can do to change it? Also, if possible, record and upload it for me to hear.
Pic 1 CMP Pic 2 FPS
Apr 2, 2023 at 12:43 PM
ADAMJH66
It changes with RPMs. It’s a very loud rattling, metal on metal type of noise. Nothing has changed it so far, it’s been constant. The video I posted is from inside the car, this is with the hood closed and it has a stock exhaust to put some perspective on how loud the noise is.
Apr 2, 2023 at 12:46 PM
  • 110,248 POSTS
I did hear it. However, the audio on a laptop isn't too good. LOL To me it sounds like a bearing issue. If you open the hood, can you tell where the noise is the loudest? Also, where you performed the repairs, was everything torqued to the manufacturer's specifications?
Apr 3, 2023 at 12:28 PM
ADAMJH66
Yes, everything is torqued down. The noise is coming from the back of the motor, around where the timing chain is.
Apr 3, 2023 at 12:46 PM
  • 110,248 POSTS
Please understand that not being there makes it more difficult for me. When you installed the HPFP, was the sleeve in the cylinder head undamaged, or was it replaced? Did you rotate the camshaft until the sleeve has reached the lowest point before installing the HPFP? I have a feeling that is where the noise is coming from. That pump is actuated by a lobe on the camshaft. If the sleeve was not fully installed, not in good condition, or if the lobe on the camshaft was damaged, it can be causing this noise. Also, you may have gotten a faulty new pump.
I would take an automotive-type stethoscope and see if that is where the noise is coming from. If it is, remove and inspect it.
Apr 3, 2023 at 2:25 PM
