Rattle under engine at low idle
160,000 MILES • 3.8L • 4 CYL • AUTOMATIC
LARAC7
At low idle, there is a metal-on-metal rattle sound located beneath the engine. This occurred after using a hand-held wand washer that sprayed water forcibly downward between the "wall between the engine and the car interior." It is suspected that "something like a heat shield" was knocked loose. The rattle occurs only when idling low then when I "step on the gas" the rattle disappears. Previously (within the last year) the '"muffler and/or tail pipe" dropped off and dragged on the ground. It was reattached with a metal wire by hand. Without putting the car up on the rack. casual observers have stated things like "alternator", "serpentine pulley", "engine lifters" etc. I know the "rattle" is not any of those things because of the nature of the "rattle". Ironically mechanics "insist" that they will only "put the car on the rack without me being present to witness the findings" and they will tell me what they find. This is suspicious because "I have been ripped off by auto mechanics numerous times" (i.e. taken advantage of because I am a woman) and have been "charged for services not rendered many times" by unscrupulous auto mechanics, "at least four times in the past four years." Recently, an unscrupulous mechanic claimed to have examined my car to estimate for "placement of a horn button" rather than opening the steering wheel and repairing the horn. He told me it would cost $150.00 to $175.00 to place a horn button (if I provided the parts) a task that would take only thirty minutes. During the "examination" the mechanic "messed with something" causing a problem with my electrical system resulting in a "beeping" sound for about 30 to 45 seconds each time I start the car. (i.e. the horn dysfunction was caused by a previous mechanic who charged me $258.00 to "tighten the wobbly steering wheel". after which he claimed that he did not cause the horn dysfunction. I need to find an honest mechanic. Can anyone advise?
Jan 1, 2019 at 12:59 AM
Good morning,
Forget any shop that will not show you the result of there findings. that is bad customer service.
As far as the noise, I would suspect the shield on the cat converter. common issue. it is only tac welded and over time the welds fall apart. they usually tie it together with large hose clamps to stop the noise. very easy fix.
Jan 1, 2019 at 1:35 AM
LARAC7
Thank you, Roy, that is what friends and acquaintances and myself have surmised and it is so very logical and obvious. Next question: "Where do I find an honest mechanic to confirm this and do the repair"? I'm totally without any family members age 75 (but strong and independent)and live on social security retirement income only. For the last four years, I've been involved in the care and welfare of my ex-husband who passed away on 11/09/18. So needless to say my needs have been quite neglected. Now, I am "starting over at 75 on my own", but "by cracky", I am determined as a wolverine. Just need a little direction and advice. Thank you ever so much for your prompt and courteous reply.
Clara
Jan 1, 2019 at 2:57 AM
What area do you live? I am in PA. and know shops around here.
Jan 1, 2019 at 3:00 AM
LARAC7
I am in "The Woodlands, Texas" about forty miles outside Houston, in Montgomery County, residing in a senior citizen (HUD) apartment community. I feel certain that "there are, indeed, some honest and reliable mechanics in this area" but, at this point in time I do not know "whom they are" and (as mentioned previously) have had encounters with at least "four shysters" in the past four years.
Also, by the way, I noticed some other people inquiring about their "1980's" and "1990's" Oldsmobile's. I sure would like to meet other people and/or "classic car owners" who "like these oldie goldies". I've been told that the 1989 Oldsmobile 3800 (or 3.8)engine is one of the best. I've had this 1989 Oldsmobile 1998 Regency Brougham for over eleven years and have had only normal "wear-and-tear" aging repair expenses. This engine has been "amazingly faithful" and I plan on keeping this baby ("Bessie") for as long as possible. Prior to "Bessie" I had a beloved "1985 Mercury Grand Marque" (named "Betsy") whom I truly loved. I love these oldie goldies. Warm regards.
Clara
Jan 1, 2019 at 3:16 AM
Sorry, Clara, but I visit Houston when I come out there to tech but do not know any reliable shops for you.
Happy New Year.
Jan 1, 2019 at 3:20 AM
LARAC7
Happy New Year "RITEBACKATCHA" Roy. Thanks for your courtesy. Namaste.
Jan 1, 2019 at 3:23 AM
You're welcome.
Always glad to help.
Jan 1, 2019 at 5:16 AM
