Rattle sound when hood open after modifications?
131,000 MILES • 2.5L • AUTOMATIC
RIJO ROGY RIJO
So I switched the factory intake with a cold air intake after that when the hood is open I hear a rattle sound coming from the engine or near it. Quick note: the engine to intake vacuum hose is extremely loose and fell of once during test drive after installing the cold air intake. I have also attached a video.
Oct 31, 2026 at 1:00 AM
  • 55,808 POSTS
I don't see the video, can you please reload it?
Oct 31, 2026 at 11:05 AM
RIJO ROGY RIJO
Here
Oct 31, 2026 at 11:09 AM
  • 55,808 POSTS
Thanks for the video, the noise does not sound bad like a bottom end noise, it sounds like something is loose. Can you tell if the noise is coming form the front of the engine like a timing chain issue? always check the engine oil as well. Plus does the noise go away once the engine RPM's have risen? Please let me know.
Nov 2, 2026 at 6:12 AM
RIJO ROGY RIJO
I think the noise is coming from the front of the engine like near the engine oil pulling thing not. The sound goes away when the cars rpm goes down and the vacuum hose been replaced.
Nov 2, 2026 at 7:01 AM
  • 55,808 POSTS
While the engine is at idle listen to the high pressure fuel pump to see if this is where the noise is coming from. Here is the location.
Nov 2, 2026 at 7:39 AM
RIJO ROGY RIJO
Okay I will see and let you know! Thank you!!
Nov 2, 2026 at 7:45 AM
  • 55,808 POSTS
Anytime!
Nov 2, 2026 at 7:53 AM
