Rattle noise while driving?
171,500 MILES • 4WD • AUTOMATIC
BUYRITEAUTO21
  • 35 POSTS
When I am driving there is a rattle noise that randomly appears and usually doesnt last long. This happens intermittently and its hard to replicate it. I checked the heat shields and those seem to be in perfect condition. I put the vehicle in park and revved the engine and that sounds normal. Any idea what this noise would be?
Thank you
Jul 19, 2026 at 3:44 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Record the driving conditions when the rattle occurs, including road surface, speed and whether acceleration or braking changes it. Have the noise localized during an appropriate inspection before replacing exhaust parts. A converter was only one suggestion in this discussion. A noise that cannot be reproduced while stationary needs further investigation rather than a parts diagnosis from the description alone.
Guidance references and applicability
Source discussion: question 1713049 https://2carpros.com/questions/rattle-noise-while-driving--1713049 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted.
Read the replies · Discussion summary and reported outcome
  • 55,694 POSTS
I have seen the catalytic converter fall apart internally which will make a rattle noise. Can you rev the engine up in neutral to get he noise to come back? Please upload a short video in your response of the problem, so I can see what's going on. That way I can help you fix it.
Jul 20, 2026 at 8:03 AM
BUYRITEAUTO21
  • 35 POSTS
I attempted to make a video to upload but I was unable to replicate the sound. I started the vehicle, put it in neutral and revved it up several times. There was no abnormal sounds that indicated a problem. Should there be other symptoms I should watch for if it could be the catalytic converter?
Thank you
Jul 20, 2026 at 5:43 PM
  • 55,694 POSTS
You maybe able to use a rubber mallet and tap on the exhaust system to see if you hear the noise.
Jul 21, 2026 at 8:34 AM
Discussion summary
The owner reported an intermittent rattle while driving. Heat shields appeared intact to the owner, and revving the engine while stationary did not reproduce the noise. Internal catalytic-converter damage was suggested, but there was no recording or inspection confirming the source.
Reported outcome: No cause or successful repair was reported.
No audio or video was available in the reviewed material. The owner's heat-shield check does not establish that every exhaust or underbody component was inspected.
Read the original discussion
