Rattle noise when driving
160,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
RUBEN PEREZ-PENA
  • 7 POSTS
when driving and I get to 40 mph and stop and does again at 60 mph. not make the noise when is parking with engine running... can be the muffler?
Feb 5, 2020 at 2:45 AM
  • 110,248 POSTS
Commonly, it is a heat shield on the exhaust system. The spot welds break allowing it to rattle. Also, it could be the internals in the catalytic converter has come loose.
Here is what to try. Take a rubber mallet and tap on the exhaust to see if you can recreate the noise. If you can, have a helper locate where it is coming from.
Now, I attached two pics below. A short while back, there was a technical service bulletin regarding a heat shield weld breaking and causing noise. The first pic shows the affected heat shield, and pic 2 shows how Nissan recommends repairing it. The pipe is under the vehicle approximately where your feet would be above in the driver's seat.
Feb 5, 2020 at 12:27 PM
RUBEN PEREZ-PENA
  • 7 POSTS
Okay, i would try, but i wonder why only make the noise when is driving? When hit the 20, 40 and 60 mph and not make the noise when is parking. even if me push the gas?
Feb 6, 2020 at 1:19 AM
RUBEN PEREZ-PENA
  • 7 POSTS
Thank you for advice...
Feb 6, 2020 at 1:20 AM
TOUGHDIVER
  • 226 POSTS
You are right it sounds like it is in your drive-line does the noise seem to speed up as you go faster? Because there are certain drive-line noises that will come and go with vehicle speed. Does it seem like it is more in the back or middle or in the front of the vehicle. Does it get louder or lower with speed or does it stay the same. I think we can pinpoint this noise please let me know.
Thank you
Joe T.
Feb 6, 2020 at 9:10 AM
RUBEN PEREZ-PENA
  • 7 POSTS
Well Joe T.. the noise is at back and just make the noise when hit the 20, 40 and 60 mph.. not all the time..
Feb 6, 2020 at 11:17 AM
  • 110,248 POSTS
Okay. There are heat shields in the rear as well. How would you best describe the sound. Is it a rattle, ticking, knocking and so on? Is it loud enough that you could record it with your phone and upload it for me to hear?
Feb 6, 2020 at 11:37 AM
TOUGHDIVER
  • 226 POSTS
A noise that will come and go at different speeds could be a wheel bearing, C/V joint or propeller shaft. The vehicle should be placed on a hoist or jack stands and check with a mechanics stethoscope.
Note: tire balance can cause a vibration at different speeds also and if severe enough can cause a noise also. If you can record the noise and attach it to the post we could maybe pinpoint it. I'm attaching repair guides and views of propeller shaft and drive axle below. let us know if this is helpful or if you need more info.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/how-u-joints-work
Thank you
Joe T.
Feb 7, 2020 at 12:38 AM
RUBEN PEREZ-PENA
  • 7 POSTS
Thank. J.t.. and all y'all for helping me..
Feb 8, 2020 at 3:12 AM
RUBEN PEREZ-PENA
  • 7 POSTS
Thanks so much guys.. i am going to check soon when the weather gets better here at Tennessee... thanks..
Feb 8, 2020 at 3:16 AM
TOUGHDIVER
  • 226 POSTS
Thanks Ruben please keep in touch with this issue we would really like to get it resolved.
And I know where you're coming from with the weather we have a lot snow and ice here in Pennsylvania also. Really difficult to pinpoint noise with this kind of weather.
Thanks again,
Joe T.
Feb 8, 2020 at 7:28 AM
