Rattle at ignition
41,335 MILES
RHOLD01
So today my accelerator got stuck due to the floor mat, and I stopped the car (Pushing down break till it stopped and then turning off car.) I turned it back on and it accelerated, and right before I turned it off, it rattled for a split second.
So later in the day, I noticed that upon ignition, the engine rattles for just a second before it turns on. Has no issues turning on, and does not give that small rattle each time. I'm wondering what it could be.
Apr 18, 2013 at 2:19 PM
most likely you have damaged the motor internally from the over revving.
did you get it fixed yet???
roy
Apr 18, 2013 at 7:29 PM
RHOLD01
Not yet. But that's the thing. It's barely a rattle, like it cranks normal and rattles for a split second at the end and turns on. And many times it doesn't make that noise at all. Im pondering on taking it in, as I have yet to get the warranty. (I just bought the car the other day.)
Apr 20, 2013 at 4:59 AM
RHOLD01
I'll add that other than that, nothing else is an issue. No check engine lines, etc.
Apr 20, 2013 at 5:01 AM
RHOLD01
And it never red lined.
Apr 20, 2013 at 5:02 AM
does not have to red line to do damage
when you take it in, just tell tem that this noise appeared otherwise they will blame it on you and hold you liable
Apr 20, 2013 at 6:00 AM
