Randomly sputters
117,592 MILES • 4.8L • V8 • 4WD • AUTOMATIC
SM09GMC
Every now then while I'm driving the power locks will start clicking really fast and all my dash lights will spaz out and so does my radio. My mph and rpm needle will act up. And my motor will stall and chug for a few seconds. It's not throwing any codes. I took it in to dealership and they can't figure it out. Any ideas?
May 24, 2020 at 10:52 PM
Good morning,
This sounds like low voltage.
I would have the battery tested for failing under a load.
Have the charging system checked as well. Even if it is putting out 14 to 14.5 volts, switch it to AC volts and see if there is any AC voltage.
Clean the battery terminals as well.
May 24, 2020 at 11:42 PM
