Randomly stalling
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WYATTTANK
So I'm working on the car listed above lx model. It randomly shuts off like three times in a row, it would stutter then shut off. it has a new distributor, and new ignition switch, and battery. the fuel pressure is good. I know it's not the ignition switch because if you giggle the key it doesn't turn off. And also it will turn back on every time after it. any suggestions?
Sep 2, 2019 at 7:11 AM
  • 55,746 POSTS
When the engine stalls can you shut the key off and then turn the key on without cranking the engine over to see if you hear the fuel pump in the tank run for 5 seconds? What brand distributor did you install? This guide can help us.
Sep 3, 2019 at 11:44 AM
