Randomly shut off after a two hour drive
137,000 MILES • 3.0L • V6 • 2WD • MANUAL
DARSIMON321
Went for a day trip to go hiking, drove the car all day no problem, made the hour trek back home and the car shut off in front of my garage. did not stall it, it was in neutral and I was in the process of pulling the e-brake then it shut off, as if i had stalled it. Just finished replacing crank sensor because it had very weak spark, have checked both fuse boxes and see no blown fuses. I can smell fuel so i believe that's working fine. Is not showing any codes.
May 21, 2021 at 4:57 AM
There are a number of things that can cause this but we need to start with finding out how many times it does this. Did it just do this one time or can you get it to do it over and over?
Here are some guides that will help with this:
https://www.2carpros.com/articles/engine-stalls
https://www.2carpros.com/articles/stall-at-idle
Also, after it stalled could you restart it with no issues?
Or did it shut off and just not restart? If this is the case then we need to run though a number of things to find out what we don't have, starting with spark due to the recent crank sensor change.
If it is just cranking and not starting then I would put money on a crank sensor issue so let's pull a plug wire and hold it against the block and crank the engine to see if you have any spark.
Let us know about this info and we can go from there. Thanks
May 22, 2021 at 10:48 AM
