A/C intermittently stops working
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
JES EVERAGE-ALLEN
Started 2 days ago, the A/C randomly won't work when starting the car. Then today flashing dash and wipers will be in the open position when starting car.
Sep 28, 2021 at 7:46 AM
  • 110,248 POSTS
When you say the wipers are in the open position, do you mean they are on? Also, what on the dash was flashing, or was it the entire dash?
Because of the model year, the best thing to do with this type of issue is to have the can-bus scanned. CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. There are likely trouble codes stored in one of the modules. This type of scan will retrieve a code regardless of the module saving it.
Here is a quick video showing it being done:
https://youtu.be/u-4syLc-ifQ
Also, let me know if it is the blower motor not working or the A/C not getting cold.
Sep 28, 2021 at 1:41 PM
