Random stalling
210,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
TOM ANSON
  • 5 POSTS
Just a few weeks ago around the time the weather started to get hot, truck will randomly stall. Only seems to be when it is warmed up. There is no consistency in the stalling, could be at highway speeds just cruising, or while accelerating or slowing down, and also at idle. Usually takes a long crank to get it to start after stalling, maybe two or three five to ten second cranks. Only slight power loss on the front fuel tank at slight throttle, not enough to have any issues getting up to speed in traffic. Back fuel pump is bad and has been for awhile, have not been able to get my hands on a fuel pressure gauge yet due to lack of money after bills and all. So just wondering if anyone may have heard of the problem and may be able to single it down a little or know if it is fuel or a overheating sensor maybe? Considering the lack of tools. Thank you.
Jun 21, 2018 at 1:40 AM
  • 55,758 POSTS
I have seen this problem on these trucks the switching valve for the tanks going bad causing the engine to stall I would change the fuel filter fist though. Here is a diagram to show you what you are in for when changing the filter out. If you are short on funds you can bypass the valve and just use the one tank should be okay.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Jun 22, 2018 at 4:57 AM
TOM ANSON
  • 5 POSTS
Thank you very much it is greatly appreciated. I will look into it tomorrow, and let you know the results. Thank you again, it has been a headache lately, haha. Been doing research constantly and have yet to find anything to narrow it down, thank you.
Jun 23, 2018 at 3:41 AM
  • 55,758 POSTS
No problem. I have dealt with this before. Happy to share the information. :)
Jun 23, 2018 at 5:05 AM
TOM ANSON
  • 5 POSTS
So have not had a chance to get down there an look around, but was able to rent a fuel pressure gauge and ran a test tonight, was able to get any fuel pressure, did not go through the work after that of starting it, since I know it runs, and want to deal with the no fuel pressure with engine off key on first, but have not had time to crawl under to check fuel filter and the selector, as its been too dark outside by the time I have a chance to.
Jun 26, 2018 at 4:00 PM
  • 55,758 POSTS
Okay, it sounds like we are on the right path to fix the problem. Let me know what happens.
Jun 27, 2018 at 5:39 AM
TOM ANSON
  • 5 POSTS
Oops accidentally said I was able to get fuel pressure, I meant to say I was not able to. Sorry about that I should have paid more attention, haha.
Jul 1, 2018 at 9:49 AM
  • 55,758 POSTS
Okay, it still sounds like the switching valve to me. They had big problems with them. Ford has them in stock.
Jul 2, 2018 at 4:53 AM
TOM ANSON
  • 5 POSTS
Alright, I will look around for prices, an go from there. Thank you again.
Jul 2, 2018 at 10:10 AM
  • 55,758 POSTS
Cheers, Ken
Jul 3, 2018 at 5:23 AM
