Not cranking over
71,000 MILES • AUTOMATIC
ARIES7
First random dozen times was a once one click no start, but then car started. Then it took several try's until a start, until now with none. Once after several attempts, used other fob and car started first try!? After one day of no start, battery power gone. Using booster pack, get power but no start. Either one click or very minimum turn over with boost. Have not tried jumping.
Aug 26, 2019 at 2:34 AM
  • 55,711 POSTS
This sounds like the battery is ready to be replaced. To be sure here is a guide that will show you how to test the battery:
and if the battery bad this guide will walk you through the steps of replacing it.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Aug 27, 2019 at 5:40 AM
