Random multiple misfire replaced upper and lower intake manifold gaskets?
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
FREDERICK HUME
I replaced my upper and lower intake manifold gaskets, spark plugs and wires. While repairing the car the plastic nipple that vacuum travels through on my MAP sensor snapped off. It was a clean break so I glued it back on and vacuum does still travel through the MAP sensor, as far as I can tell. Only I now have a random misfire with no (MIL) check engine light illuminated until I drive the car and it starts flashing. Could the MAP sensor be my random misfire?
Nov 24, 2025 at 7:24 PM
KRAKENAUTO
  • 108 POSTS
It won't usually cause such, have you rechecked your repair to ensure you didn't booger an injector or wire up? Also what quality of plugs and wires did you use in the repair? If the parts are cheap aftermarket you can try testing it by replacing it with the old plugs and/or wires and see if the misfire goes away, if they were not too bad to start with.
Nov 25, 2025 at 1:37 AM
FREDERICK HUME
I bought the plugs and wires from Advanced auto. If the issue was a faulty plug or wire, wouldn't I get a code for a specific cylinder as opposed to a 'random' misfire?
Nov 25, 2025 at 5:06 AM
  • 55,616 POSTS
I agree with KRAKENAUTO, Also this car uses a MAF sensor as well, I would change that out and I would make sure the MAP sensor is not leaking at all, any miss reading from either of these can cause a random misfire. This guide can help as well
https://www.2carpros.com/articles/automotive-engine-misfire-code-p0300-causes-and-solutions
Please go over this guide and get back to us.
Nov 25, 2025 at 6:09 AM
