Random misfiring
137,000 MILES
PEDRO REIS
Engine is a statement L76 V8
Drive side bank three cylinder is not working.
Passages side two of them are not working as well.
I swap spark plug not working same cylinder fail.
swap coil packs not working same cylinder fail.
Swap spark cables same cylinder fail.
Any other suggestion what problem could be?
Thank you for your time
Sep 6, 2016 at 3:56 PM
  • 55,694 POSTS
Check the fuel injectors they can fail, causing the problem you have described, here is a guide that will help you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please let us know what you find so it will help others.
Best, Ken
Sep 14, 2016 at 11:29 AM
