Random misfires
219,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
MASHCRAFT1969
New plugs, coils, injectors, cam sensor, crank sensor, TPS, ASD, transmission, ECU. Still random misfires!
Jul 29, 2019 at 7:18 AM
SCGRANTURISMO
  • 4,897 POSTS
Can you please check for any vacuum leaks, especially around the intake manifold. A vacuum leak is notorious fire causing misfires, random misfires, and a whole list of other driveability concerns. Here is a link for you to go to below:
Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 29, 2019 at 3:48 PM
MASHCRAFT1969
I will check Friday afternoon and get back to you. Thank you.
Jul 31, 2019 at 4:53 AM
  • 55,746 POSTS
If I can jump in here, I have seen the MAP sensor do this I would remove it and see if it holds vacuum here is the location. Check out the diagrams (Below). Please let us know what you find.
Aug 2, 2019 at 8:59 AM
