Random misfire, codes p0300, p0301, p0302, andp0303?
127,610 MILES • 1.6L • 4 CYL • TURBO • 4WD • AUTOMATIC
QUARLES01
Yesterday, I'm going down the interstate my car just started stuttering and stalling and it was like I wasn't even giving it any gas. The check engine light came on and started flashing. I have over 11 years' experience of being a mechanic, but nothing on this new model. It's got a misfire code on all cylinders except for four. So, I swapped the coils from three and four and three is still misfiring and fours not, so I don't think it's the coils. The past couple of months whenever I gas it to pass somebody or something it would kind of stutter for a second and it made a sound, and I was worried it could be the turbo gasket or maybe it was an exhaust gasket, but it's always pulled just fine. I put brand new iridium NGK spark plugs like it required yesterday and that didn't help at all.
Sep 18, 2022 at 5:49 AM
  • 55,743 POSTS
I have seen both the fuel pressure sensor and the MAP sensor cause this problem which is the value of the sensor changes a little which affects the fuel mixture, when this happens it is not enough to give a trouble code for the sensor just the results of the failure which is the multiple misfire codes. I would try the MAP sensor fist here is the location of both sensors in the images below. Please let us know what happens.
Sep 19, 2022 at 5:22 AM
QUARLES01
Could it be the intake manifold gasket?
Sep 19, 2022 at 9:38 AM
  • 55,743 POSTS
Yes, it could, to be sure test the engine when it is cold and follow this guide:
Please go over this guide and report back.
Sep 20, 2022 at 4:02 AM
