Random misfire
160,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
Had a misfire code on cylinder eight. Changed the coil pack. When I drove it again it didn’t have much power and another code for misfire on cylinders two and three. Should I just change all the coil packs or is there something bigger causing the loss of power issue?
Apr 1, 2019 at 11:58 PM
Good morning,
What about the plugs? They are just as important as the coils.
Did you do a compression test?
Random misfire is usually caused by low fuel pressure. Have you tested the fuel pressure?
Apr 2, 2019 at 12:24 AM
