Random crank but no start
196,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
BGREENARD2
I have the truck listed above (SS). I have been plaque with a random crank but no start. If the problem happens, it always starts on the second try. I have replaced the fuel pump, ignition switch (in the column), and key switch. any ideas?
Aug 10, 2021 at 2:52 AM
SQM
  • 6,383 POSTS
Have you checked the crank position sensor?
It almost sounds like an issue with the crank sensor.
Many times a faulty crank sensor will make it difficult to start the engine.
It can also create intermittent starting issue. The crank sensor does require programing for these trucks.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Is your check engine light on?
Let me know your thoughts.
Aug 10, 2021 at 3:23 AM
BGREENARD2
I have no codes except for Airbag. Excellent suggestion, I have seen them became faulty on other GM vehicles but didn't consider on my Silverado. I will look into the crank sensor. I appreciate the speedy response.
Aug 10, 2021 at 4:13 AM
SQM
  • 6,383 POSTS
You're welcome.
Keep me posted.
Aug 10, 2021 at 4:31 AM
BGREENARD2
Found out the crank sensor has recently been changed recently. Will check the fuse box. feels like a sticky fuse. Spit balling now.
Aug 11, 2021 at 11:00 AM
SQM
  • 6,383 POSTS
Is it throwing any codes?
Aug 11, 2021 at 11:15 AM
