engine overheats
250,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
KATRINABORCHEF
Started with no heat from heater then overheated with no water in radiator and oil was real low. Fluids were replaced but still no heater. I question if there is water in radiator at all. Now engine runs terrible does not shut off, but feels like it has a bad spark plug or two. Is it in safety mode? Is another way to get water in radiator besides the overflow container?
Mar 28, 2018 at 4:25 PM
  • 55,748 POSTS
You can remove the upper radiator hose and pour the water in when the engine is off but you should not need to do that. To me it sounds like you have a blown head gasket which causes the heater not to work and the engine to over heat. Here is a guide please follow it and report back:
Cheers, Ken
Mar 30, 2018 at 4:44 AM
