1998 Ford Expedition engine overheating problem
MUSICMAN126MRJ
  • 1998 FORD EXPEDITION
  • V8
  • 4WD
  • 156,000 MILES
My temperature gauge would rise to the middle and then after a few minutes it would rise to rise and the oil light would come one. I rev the motor then drop it back into gear and the gauge goes back to normal. I thought it was the thermostat so replaced it. Now the temperature gauge shows that its overheating after a few miles and the truck overheats. Ford said that it was a head gasket, but I not leaking any coolant. I read that it might be the fan might not be working but I checked when the truck is overheating and the fan is working fine. What else could it be? I thought maybe the water pump?
Friday, February 19th, 2010 AT 4:29 PM
  • 109,885 POSTS
When does it happen, on the highway or intown driving? Also, have you replaced the thermostat, flushed the cooling system?
PS: A bad head gasket could cause this problem.
Monday, February 22nd, 2010 AT 11:26 AM
