I have the LXi model. It has radio P56038620AJ. There is a multi-disc changer mounted below the radio. My problem is that the radio turns on but delivers no sound to the speakers. I pulled the rear two speakers and noticed that there is mini-amps hooked to each one. It seems that power is getting back to these amplifiers but no other signal. I am stuck. I have read the other posts and am going to check to see if 12:00 shows up every time I restart the car. I wanted to give you my specific specs to see if you could help me pin point the problem.
Aug 22, 2017 at 10:01 AM
