Radio works intermittently?
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOMJRIZ
The radio won't turn on. There are no blinker sounds either. But every once in a while the radio will just come on out of nowhere. Seems like some kind of short. Could it be a bad radio maybe? The fuse is fine.
Sep 16, 2022 at 6:47 AM
  • 55,647 POSTS
Yep, what happens is the amplifier inside the radio startts to go out this is why it pops on all of the sudden, you can get a used radio from a used parts house or check ebay, they have a bunch of used ones. here is how you can remove the radio in the images below. Please let us know if you need anything else to get the problem fixed.
Sep 17, 2022 at 3:00 AM
